Well, I got a few more things to do and I should be able to fire up the car. I installed the intercooler, piping, radiator, heater lines, 3" Downpipe & "Cat"
(thanks Grumpy!) & Accesory Drive. I had to cut a little bit off the tranny to clear the downpipe flange but it bolted in perfect!!
I still need:
custom driveshaft(TH400 to 7.5" 10 Bolt.)
Fuel Lines(body to Fuel rail)doing -6an both sides
Oil Feed to Turbo(debating -4an)
TTA Radiator hoses(found on Napa Online, Gates hoses)
5/8" Power Steering Hose
finish vaccum lines
Oil Pressure Gauge
Throttle Bracket
Cam Sensor Timing
Fuel Pump Hotwire install
& a little more wiring work
Send my Turbotweak chip in for VSS & P/N Delete
Figure out TH400 Shifter
It's getting closer to D-Day and my wallet is paper thin
Im estimating about 4 weeks until it is ready to fire up
It's mostly nickel and dime from here on out. Mostly everything I need to finish I already have. I'll try to get some up-to date pics soon!!!
