TURBOPOWERED68
David
- Jan 31, 2006
Front mount IC is in and so is the trans cooler
SignUp Now!Radio is in and working. Bluetooth and all BTW the speakers are shit.Pic of new motor? Did you put a radio in?
ha ha , take notice guys this is what friends are for. lolsince you have them off .. make sure your the brake setup will fit in your rims , if they fit . might as well do it ..
cant use the drum prop , you need a 4 whl disc prop valve or gut the original
dont think the fbody prop takes same fitting (metric bubble) as the gn (SAE inv flare), hiwaystars has the 4 whl prop
but without a motor i dont think youll notice the difference from drums![]()
Do you have a write up or pictures on "swisscheesing" the front metal bumper support ?since
not how i would have done it but its your carFan is in with a custom "PMiller Racing & Fabrications" wire harness. THANK YOU SIR.
I left them on there for the ocd guys. Lolnot how i would have done it but its your car
...needs more long zip ties
btw that fan has been mid 9s ....racecar parts
