I have a black 87 Turbo T. Parts I have to be installed is as follows:
1) Moser rear girdle w/gm posi additive and Royal Purple Gear Lube 75w/90w
2) UMI red colored sway bar (stock control arms for not, later metco's)
3)Suspension techniques coil springs and front sway bar
4) UMI red driveshaft loop
5) Bilstein shocks all 4 corners
6) BFG Drag Radial 275/60/R15 on turbo T wheels.
6) SSBC twin piston front brake calipers & Pads
7) Cross drilled rotors
8) Vacuum brake conversion to be installed (have all parts)
9) Pypes Cat back with GN tailpipes & test pipe
My 86 SS MC has a simular set up except that there's no rear end girdle (7.5 diff, but I have an 86 GN rear complete with driveshaft & BRF tranny), bilstein shocks all 4 corners, suspension technique springs, addco swaybars "anodized gold color, UMI driveshaft safety loop, pypes header back system with GN tailpipes.
This my street/strip set up not including the thousand of other mods to the engine. Just a thousand mile journey accomplished 1 day/part at a time.
