czimpel
Boost...gotta get some!
- Aug 16, 2012
I figured I would share what I've been doing so far this winter. Finally had some time over Christmas to clean the garage and get some things done on the 87 GN.
I'm not one of the big stage 2 guys on here doing all the fancy machining and spending thousands, but it's a start.
Started working on pulling the old turbo and down pipe off to get ready for some new to me parts. Thanks coach for the dp and 87chriss for the 60-1 turbo. Can't wait to get the parts and start putting them in.
While I've been waiting, I pulled the valve covers to put in the new sealed power vs677 springs. While they were off I decided to start doing some of my own customizing to the stock parts.
Since I needed to do some painting with the GN in the garage I decided to build a small lighted spray booth to paint some of the small parts. I had a blower fan and some foil face insulation, so I decided to do it somewhat correct so I didn't get a ton of cold air coming into the garage from it.
Painted the valve covers black and sanded off the ribs for some aluminum to show. Also painted the up pipe and coolant line since I had to remove them to get the pass v cover off. What a pain.
Next project will be dropping the trans to put in a different converter from 87chriss, and dropping the fuel tank to install the dw300 I got from coach.
Will be switching to E85 thanks to jdpolzin for all of the turbo, trans, and injector help. Next purchase will be 120s, modded ECM, and tt chip. Hopefully this will satisfy me for the summer. Can't wait for the snow to melt!
