Hey all.
I have a non-turbo '83 Limited that's been giving me trouble lately. It's been extraordinarily anemic since I swapped the motor from a '77 or '78 Monza into it last August, but that's not really the issue right now...
My oil/choke light (which, might I add, I consider to be the absolute worst combination of idiot lights on the planet) had started going on intermittantly recently. I could get it to go off if I gave it a lot of throttle, but as soon as I backed off and started to slow down, it came back. It seemed to come and go as it pleased and never really affected performance any more than was already affected, and it didn't make any more noise or vibration, so I just assumed it was the choke sticking as always.
In the past few days, though, it has started to come on solid and not turn off, no matter what I do.
It's probably just a coincidence, but this has coincided with some torrential rain that I had to drive through in Central IL in the past week or so.
Anyway, so I took a look at my old carb that was on the motor, and inspected it. It was leaking gas terribly, and there was varnish everywhere, and the choke had never really liked working to begin with, so I bought a rebuilt replacement from Autozone and installed it. I have a lot more power now, and it no longer stumbles or bogs anywhere in the RPM range like it used to. However, the oil/choke light is still solid, and my cold starts are terrible.
No matter how much adjusting I do, I have either a very fast idle, or a surging low idle that tends to kill the car when I put it in gear unless it's warmed up.
I suspect it has something to do with the computer-controlled portion of the carb, since everything seems to be tuned properly with respect to the mechanicals. Unfortunately, I don't really know where to start to fix anything about the electronic part.
I'd appreciate any help/suggestions you guys might have.
Thanks.
Thanks.
