N/A Bucik - Holden Commodore
guerd87
hi there guys, im from Australia, not sure if you ahve any/many member form over here
just thought i would ask a few questions :)
over her ein Aus, we have a varient of your turbo buicks afaik, they were installed into the 1989 - 2004 holden commodores(GM)
i have a 1990 VN commodore, it has the series II buick 3800 motor, running through a turbo700 4 speed auto, and i wish to add urbo to it to up the power, seeing how much of a result it was in the GNX series :)
here a few pics of the motor and car i have
My Car
My Motor
outof these pics, and i can give you more info if needed, what type of mods would i have to do to get these to a trubo state, im tlaking as in internal rebuild and fuel system?
any help and advice appreiated
cheers
guerd
Look on the LS1Tech.com for more Holden stuff
I've heard of them, been looking at them because they installed the Supercharged 3800 in a rear drive car. I've been trying to find someone in australia that could find me a rebuildable M90 supercharger core for me to use in my rear drive conversion on an 83 Dodge Shelby Charger. You know of any salvage yards in yoour area with one of the cars that has a supercharger still sitting on the motor because it was making noise? I could use my current supercharger and just make an elbow for the throttle body but I'd like to see if I could get a hold of a rear drive blower to prove to other people that GM did make them. Thanks Brad Zeidler
yes thats correct, they use the eaton m90 supercharger on the vs,vt and vu series.
as for a second hand one, the only place i could thnk of around here is Barsby's Spare parts
you could buy themknew off holden or eaton themselves, a good reseller is Capa Performance but as you would expect, a little pricy
if you guys need an other help just let me know, ill try my best
soo, anyone else know about turboing the olde buick?? :D
Hey, I don't think The VN engine is the series two engine, I think the Holden ecotech is the series two engine. The original buick V6 Holden used should be the late 80's FWD engine from the states but in RWD, the question I have is how strong are those engines?. Because I want to install a turbo on mine. It has been done here in Australia before but there isn't much information around on how much boost the stock engine will take before it breaks or what parts from the US engines will fit on the RWD 1988-1995? Holden engines, I guess just about everything except the crank rods and pistons are different
