I picked up an 85 Cutlass with a 3.8. It seems to not have the power (can I call it that?
that it should. It does have the gauge package so I will tell you what some of the readings are.
It starts out with around 30psi while idling and after, but the longer it runs the lower it gets especially after driving where it drops to 5 or less at idle. If you bring the RPMs up around 1100 the oil pressure comes back up but only to about 15-20 psi. Also when idling it is fine but if you bring the idle up to about 1500 rpm there is a faint sound almost like a ticking. It sounds like it may be coming from the# 1 cylinder. I know what a rod knock sounds like and this isn't or at least isn't yet. The engine runs smooth other than the light noise and even gets up though not as fast as it should but the oil pressure bothers me. I am thinking it's the bearings or maybe a bad oil pump? What do you guys think?
Until I noticed the oil pressure I thought maybe the timing was off.
Any help is greatly appreciated.
Thanks for the help,
Jason
Jason
