Hi Guys, Rich,the TBI pumps are just like the SFI and use a return line to control some of the pressure. They make great pumps for use on carbs if a regulator is used inline. Also if you can find a fuel pump catalog GM has some lower pressure pumps they used for some carb applications(70's Skyhawk and Monzas come to mind). Right now I have my 82 Regal plumbed with the fuel lines from a 86-87 TR. This car is still in the construction phase and for now I am running a Q-jet but in the future I plan on running EFI hence the SFI turbo lines. All I did to hook up the carb to the EFI lines is to use some factory pressure hoses from a 3rd gen Camaro with the PFI V-6 and cut the fuel rail side off and clamp the hoses to a Stage 1 fuel pump. I am running a NA sending unit in the tank.
Eric
