RockfordEsprit
- Apr 11, 2003
Hey All,
On my '81 bird (3.8L E/C N/A 2bbl) I have a problem where I go to full throttle from idle, and it backfires a bunch of times and hesitates, then goes. I have just replaced the following components with brand new as of yesterday:
Carburetor (DualJet E/C)
Coolant Temperature Sensor
MAP sensor
Spark Plugs (BOSCH Platinums)
I thought about replacing the ECM and/or the distributor as this might be the problem. I also had a computer error awhile back:
"SPARK CONTROL BYPASS CIRCUIT GROUNDED" (via Diacom)
This error has not returned, but I still suspect it may be a problem.
I also have an intermittent miss while the engine is warm, possibly unrelated.
Anyway, you guys are the experts, what do you think?
Thanks!
Julian
MAP sensor
Thanks!
Julian
