Name that fuel fitting?
waell
...help me out, the size slips my mind right now and I couldn't quite pin-point it in the search feature.
You know the ONE needed for hooking up a fuel pressure gague line to the fuel rail.
I'm running the line into the car with the isolator kit and need that fitting for the end of the line and the stock fuel rail.
so I need a -4 an female to -4 an male to hook the line to?
Is this right?
any part numbers?
any help here would be great before I go and get the wrong part again :mad:
thanks
Fuel fitting.
The fitting on your fuel rail is a standard A/C type schraeder valve. The way I hooked mine up is just put a short piece of 1/4"(-4 AN) braided fuel line I had laying around on this fitting. But to do this I took out the tire valve that is screwed into this fitting. A typical tire valve tool will take it out. You could do the same thing but just run your line to your isolator. Look in Summit or jegs for -4 AN. If you have the isolator kit it should have the right size line with it. John
