Name this part
Bescurred
BOOSTED SHAMU v2.0
I think it has to do with the door chime but I dunno...
Looks like the ground and the power have been cut
where are the wires going to? Green wire looks like possibly high beam headlight...
Could be a relay from some aftermarket gauges.
Thats a relay none of those wires look factory. Possibly for a interior toggle switch to run something. Did you have any switches in the car?
Its under the steering wheel # shows c9405...it did have a theft deterrent switch...maybe that's what it is I gotta follow the green wire
Definitely an aftermarket relay designed to power some sort of accessory in the car. Only way to know for sure is to trace the wires. The thin wires will run to the trigger mechanism and the thick wires will run from a power source to whatever it powers.
