Need 86/87 MAF sensor
Turbo Keith
TURBO KEITH
I'm having some issues with my car , I need an extra MAF sensor to do some testing . Thank you Keith
If you want to upgrade to a Translator i have a tested working LT1 sensor for $50 to your door
I know this is crazy but todat I took the MAF sensor off and the 2 mesh honeycomb filters had come loose and turned sideways in the sensor , I took one out and fix the other one with the keeper and she is back running fine . I just installed a ta49 , 60 lbs injectors and a front mount IC when this happened . I guess I'm very lucky as this is all that was wrong .
Very lucky....
do you feel confident that screen that's still in there won't end up in your compressor wheel?
