need a good buildup idea...
ll3lue
ok i want to map out a drivetrain build up for my car and something to work for...
now basically its got
TE44 ( i think) lol
36lb blue tops
stock intercooler
stock D5
MAF translator
tranny rebuild w/ b&m skiftkit
big kn air filter...
now for the goals
my goal is to keep the car tottally streetable..so if i were to drive it 50 or 100 miles i'd have no problems but also be running in the 11's or maybe even 10's in the 1/4, i want a part list that i can just start chipping away at for this goal..i'm gonna get alky for sure and i know its gonna be needed to run these times..but what else should i get? the car is pretty stock, what intercooler, turbo, injectors *i figured 50lb*, what convertor w/ what stall
I know that you might get some people that wont agree but I like the Motoron 60lbs injectors. Unless you are going buck wild these should be the last set of injectors you will need. The PT61 is a good street turbo that can go high 10s.
If you get the pt6131 you can still use the stock converter. You should pick up a good 3 inch down pipe. I did not see you other fuel system upgrades.
You will need a good fuel pump, AFPR and hot wire kit.
I'd have to second most of what John just said. I would go with at least a 46-50 lb injector, 3" atr or houston downpipe, and a good exhaust kit are must-haves; as are the fuel system upgrades he mentioned.
Wow, I should show this to my wife.
Someone can actually agree with me! ;)
