need a lil help tuning
kraus
I just got motor and everything back together and running.Installled alky kit bla bla bla,i am only running 12 lbs of boost right now.I am getting 1.2 knock when it shifts into 3rd at a 11.5 wbo2 reading .It is in this 11.5 range in 1st and 2nd also with zero knock,but 3rd i see1.2. i have not adjusted anything in the box for gain etc.I have the dial on the alky box set at like 7-8 should i be turning that up or should i go into the pac one and turn the gain or pump up. I have not pulled any fuel out on my tt chip at all,also have not changed timing in it at all. Where should I start.... it is activating alky about 4-5lbs of boost etc.just has knock at 3rd again this is at 12lbs no more or less.thanks in advance guys...
At 12 lbs you shouldnt need any alky. Shut the alky off and get the car running 100% at WOT. Typically 15 PSI should be attainable..
So once you have 12 PSI working correctly... switch the alky on.. and start at like 5 on the GAIN.. and start turning up the boost.
I bet its something not alky related that is cuasing your issues. And do not go into the PAC box.. that will add more issues.. trust me on this.
Post back when you have it running correct at low boost.
