Need a picture of GN spoiler installed please
buddy
I purchased a uses GN spoiler and the for is pretty bad, mostly to the quarter panel extensions. Can somebody please post a picture of how the fit is supposed to be on top of the quarter extensions. Rear view and front view. Also, has anybody ever molded in the sides and or while thing for a smoother look? Car is going to paint soon and need to get everything fitted first.
Thanks, rich
Hope this helps
Cool man thanks a million. !! My spoiler overhangs the same amount as your and it didn't seem right but I guess that how it is. Is there airspace if you look up from the ground on the two sides?
is it typical for these cars to not line up good on the trunk?after seeing yours mine is about the same.is this typical?
Mine fit pretty tight. Sorry for the bad pictures, using a flashlight. Need to get the 25 years of wax out too.
Thanks for the pictures. Mine has a lot more space than that. I guess I'll have to shave it down. Can someone confirm that the sides are held only with double sided tape and the center has the two studs along with double sides tape?
Can't help you there. Never had mine apart as you can tell by the faded paint. It looks like tape on the end caps. I will check tomorrow morning.
