Hey guys-
I'm new to the whole turbo thing, but a post was put up for a "hot air" motor and acc. What I'll thinking about doing a swap out with my F-body (4th gen V6 3.4L). I know doing this swap would not be an easy thing and that does not bother me. What I'm curious about is more power/boost for a hot air engine?? I've seen some sigs with mid 14's on these cars and I know the 87 IC motors are pulling 11's or lower. I would like to get a good 12 out of something like this. So... for the questions:
- Can the turbo be moved off the top of the motor with different manifolds or other way? (motor is under the dash/windshield on the F-body)
- What are the down sides to a 85 setup vs. 87 setup?
- How hard is it to IC an 85 setup?
- Do I need to run an auto or can I continue using a manual trans?
- Does anyone know of a Detroit shop for motor work? (obviously a rebuild is in order)
[/list=1]
Any other help/suggestion you all have would be great. I have to consider you guys as experts in this arena because you guys own/modify them, I don't (yet)
Steve
