need for a brake
j-6
im currently leaving on 10-11 lbs of boost my 60ft. is around 1.50 im kind of want a brake but then I dont do you think the brake will help anymore or do I needto keep practicing on launching off with the ten with stock suspension.
I'm sure many will say that you only need a brake if your footbrake cannot hold the power you are making at your launch boost level.
I'd say work on the suspension rather than changing the launch method. sounds like it's working pretty well as is...
Thanks Double D
