Car is a 87 grand national upgraded turbo, mag 4 ecu chip and a few other mods
Ok quick run down of what I've ruled out before the suggestions come please, also I do not have a scan master unfortunately.... Yet
Also while in neutral car will rev throughout rpm problem only occurs while under load in drive...
Compression test was good on all cyl's
Fuel pressure at idle is good *cant read a wot psi*
cccim and coil pack are both brand new
Plugs and wires are brand new
Cam sensor is good and working
Crank sensor is fairly new
Fuel filter is brand new
All fuses are good
Turbo spins freely and has verrrrry little play
I assumed the maf sensor was bad after having cleaned it and the sputter got worse, but I recently switched mine with another known working maf from a friend with a 87 t type and the problem continued with his maf connected...
Kinda in a rut now can't really think of anything that might cause this any help is appreciated thanks!
This a video of it with my buddies known working maf.
All fuses are good
