Hi,
I have an 87 Grand National w/114k miles on it. I recently purchased this car and apparently it has had a fair amount of work done to it. The current issue is this:
Once started the car will run/idle ok for a few mins. After driving for 5-10mins, no faster the 35-45mph, the car 1. sputters, 2. Check engine light comes on, 3. Scan master turns off and on, and then stalls. It started doing it off and on, now it is more regular.
Here is the current combo.
109 block
center billet caps
main studs
Eagle forged crank
Girdle
.040" pistons
head studs
Adjustable FPR
Hot wired fuel pump
Tin Man Cold air kit
206/206 flat roller cam
stock rockers
rjc power plate
Razor Alky kit (just installed)
TE60 turbo
60lb injectors
Fbody radiator
Oil Cooler
Tranny Cooler
SLIC
3" ATR downpipe w/ wastegate (just installed)
Magnaflow exhaust
3200 stall converter
built trans
stock rear
Scanmaster
Found that the battery ground wire was ground to the frame instead of the engine block. That has been corrected and it is now grounded to the block, if that makes a difference.
Any ideas as to what could cause this?
109 block
center billet caps
main studs
Eagle forged crank
Girdle
.040" pistons
head studs
Adjustable FPR
Hot wired fuel pump
stock rockers
rjc power plate
TE60 turbo
60lb injectors
Fbody radiator
Oil Cooler
Tranny Cooler
SLIC
Magnaflow exhaust
built trans
stock rear
Scanmaster
