boostmaster
- Aug 20, 2001
okay guys, i hope someone in here can help me. i resently purchased a spearco water injection kit. the instructions for this kit are very vague and do not give specific instructions on installation. okay i have drilled, tapped and installed spray nosal down stream of my turbo,by the way it's a hot air t type. here's the problem i know that the hose coming from the nosal goes to the pump which gets fed from the tank, here's my problem i'm using the included boost sensing switch to regulate the switching on and off of the spray at boost. i also know that this goes to a line down stream of the boost. the problem is the reference line on the top of the tank , do i also use it if i'm using the boost sensor or do i plug this line. thanks, hope you can help me.
