boost is set at 15lbs,O2 reading was at 800,0.0 knock. after wot i got a little pop, and got to a stop sign and idle is surging . it did this a couple days ago and i unpluged cam sensor and it quit, so i reset the cam sensor with the cam tool,put in a fresh set of plugs and she was good as new. oh yeah i pulled a little fuel and some timing,timing is about 15 degrees on my TT chip. now it did it again. Eric said my injectors were to small so he set my duty cycle at 100% in higher rpm's. do you think my injectors are locking up? look at my sig for combo,thanks any help would be great..
