http://www.highperformancepontiac.com/tech/0309pon_turbo/ good article to start with. A blow through carb will work, keep in mind that you're probably gonna wanna keep the compression ratio low if you build a turbo motor, and any sorta cast pistons are risky for a large amount of boost too. The headers can probably be bought through Poston's ATR, and a few other places as well as the marketplace. The headers will NOT fit a lot of standard (T3/T04) flanged turbos, but rather fits a 3 bolt flange. Then again, you can get a good condition stock turbo for a decent price if you look, and that should be more then enough. My personal opinion is that if you can fit the turbo near the standard cast iron "logs" you'll get good performance from them, they retain heat well. Far as it goes, any other advice would probably be best given with knowledge of what you wanna do.
well heres the deal im going to build it and make the turbo kit and put it on the 3.8 but latter on im going to rebuild a 4.3 bottom end up but i need help finding a turbo for less then 700.00
