Scottie-GNZ
- Jun 14, 2001
The 52, 54, 60, 61 & 62 turbos all use the same T04B 60-1 compressor wheel, but each uses a different turbine wheel. It is pretty straight-forward to estimate pressure ratio and flow and see how those plot on a compressor map. However, we know all those turbos are not equal so the difference must be the turbine side. How does the various turbine wheels impact turbos using the same compressor wheel, HP-wise, spoolup, driveability, etc? How would each of those spool relative to each other and to a 51?
TIA
TIA
