I have installed a new Neal Chance torque converter in my car. When the motor was out (due to a needed head gasket change) I noticed that my cam was going flat. I selected a cam that would move some of the low end power to the upper RPM range. Now my new Neal Chance converter that was order to stall at 3000 RPMs+ will either spin the tires at 2400 RPMs or push the front tires. Marty the owner of Neal Chance is blamming the cam shaft change for the low stall number. I say if I cannot hold the car back when it is making 100 HP at 2400 RPMs then it makes no difference if it is making 400 HP it still would not go above 2400 without breaking the tires loose. Any thoughts on this? Am I wrong? Is blaming the cam change a cop out by Neal Chance? All comment and opinions are welcome. BTW the car is down on power in the lower RPM range but pulls much harder on the top end. I say if the torque was looser then some of the low end power would come back and I would not have this problem. The torque converter will not allow more than 2400 RPMs at no boost or if I hit it at 5 lbs of boost. What do you guys think?
Jim Armbrust
Jim Armbrust
