need help what cam to run
JustAnotherSix
ok guys i need your help on what cam to run motor in the car is basic .30 over all arp ported irons and ported intake 3200 stall i have a pt-52 on the car rite now bout when the funds are there i will be going bigger so what cam should i run so im not over camming the car i been looking at the hot street cam from full throttle speed here is the link to the cams lmk guys need you help thanks FULL THROTTLE SPEED - Revolution X Roller Cam Kit Morel Lifter
Available Grinds:
206/210 .516/.516 110 L/S
Good stock replacement and driver cam 2800 stall
worked great !!
i would go either the 206/206 or the 212/212. i would probley lean towards the 206/206. these two cams are proven. if you would like more info call nick micale at www.arizonagn.com and he will set you up for what you need/ goals are.
we have used ALL 3 of the cams posted.. All were great .. easily run 10's with them .. idle great with good street manners :cool:
