72firebird
- May 18, 2004
well a friend of mine has a repair shop and a guy just brought in a 84/85 GN and said it stumbles, that he just bought it, and doesn't know whats wrong with it. I guess the guy sold it to him because he couldn't figure out the problem. I don't have any real hot air experience so I thought I would ask about the opinion of those on TB. On to the problem.
The car runs great when parked and you can rev it all you want and it runs smooth. However when you take it out it gets to about 6 psi (really hauls ass up to it and starts destroying the tires) and then it just seems like it dies. The boost will still increase up to 15 psi but obviously the performance isn't there.
The mods on the car from what I could see are K&N, turboxs boost controller, MSD wires, SMC Alcohol injection V2.0, ATR exhaust and downpipe, fuel pump hotwire kit, AC delete, and a Turbo Tweak chip in a 86/87 computer. It says on the ordering instructions that it is a chip made for a 84/85 with a 86/87 computer so I don't think that's the problem. I think it might be the fuel pump because I can't find any papers that have information on him ordering a fuel pump just the hot wire kit. The fuel pressure is around 45 psi at idle with the line off. The motor and tranny supposidley only have about 2k miles on it. The tranny shift really good and the motor seems to be solid. The Turbo Tweak chip is suppose to be made for 22degrees timing in 1st/2nd and 20degrees in 3rd/4th for 20-21 psi.
Right now there is now alcohol in the tank but we'll be adding some tomorrow. I'll also be taking my turbolink over there to help diagnose the problem. I was just wondering if there are any common problems like the fuel pump that I should look at. If you have any questions I will try to answer them the best I can and any help is greatly appreciated.
