Need help with front upper A-arms
Slowhawk
I replaced the bushings today but broke the inside washers on each arm.Of coarse after I was done I forgot if they went towards the front or rear of the arms?
Does anyone know?
They are on the main shaft and work as a spacer.
In order....... shaft goes thru bushing hole in arm....... bushing.. then washer... then nut
Yes,but mine has a washer in the inside of the bushing.
Mine went shaft,washer.bushing,big washer,nut.
