It would be awesome if you guys would suggest what I should try next.
I switched from S/C to turbo and also installed a mild turbo friendly cam from cam motion. I get 18" of vaccum @ 1100rpm
Now I'm trying to set idle. I can get it to idle steady and smooth at 1150-1200 rpm. This is with the idle speed set at 1000 in the idle table.
For some reason I can't get it to idle lower with the idle speed surging up and down. I would like 900rpm. this is a manual trans.
The idle follower is about 60-70.
timing advance is 28 deg. I've tried 20-33 deg.
I'm using open loop until 2000 rpm.
a/f target for idle is 14.4 (I've tried 13.8 - 14.7)
VE at the cells during idle is 89-93
