R_Andersen
- May 29, 2001
Guys, I'm running Bosch 42.5 lb injectors and need some help with the injector constant for the chip. I'm currently running a 30 (hex value) constant and with this constant I have to run about 35psi static fuel pressure for the blm's to be close to 128. I'd like to change the constant to bring the fuel pressure up to about 43 psi. I'm just not sure what I should change the constant to. I was thinking something on the order of 26H-28H but I'm not really sure. Is there a formula to convert the constant to a real world value, i.e. 48H = 28 lb/hr?
Also, is this the best way to get my fuel pressure to where I want it? Any advice will be greatly appreciated.
