Country Nate
- Jul 7, 2014
To make a long story short, I own a 1986 GN with 57,000 miles on it. I purchased the car new in 1986 when I was 19 years old. I drove it a lot the first couple of years, and then very little in the last 20 years. Mostly sat in storage. I know the car does not run like it did when it was new. It seems a little sluggish, and it idles a little rough, especially when cold.
At this point, I have decided to get the car running correctly again, so I found this website, and I have been reading, and reading for the last couple of weeks. Time for me to start asking questions.
Everything except the torque converter is stock, even the chip. In 1998 the torque converter was replaced because my dad was racing the car around and somehow managed to burn it out. He took it to Cottman Transmission to be replaced, and I have no idea what they put in it. I wasn't paying attention. I took the cover off last week, and it is 12", and bright orange. Only numbers I can find are C48 4802 A7. Whatever it is it, "stalls out" around 2000 rpm's. When I say "stalls out" I used two methods. When braking, the wheel starts turning at 2150 RPM's, and the boost starts to light up at about 1900 RPM's. From what I gather on here, I should replace with one that stalls out a little higher around 2500???
I got a scan master a couple of weeks ago, hooked it up and here are the readings:
o2- bounces all over the place while driving around. WOT, it's about 830 until I hit third, and then it drops back into the 790's.
Knock Sensor is almost always on 0. Even WOT. I did see it jump up to 1.4 once for about half a second under WOT.
AF- 3 when I turn the key on. 4-7 during IDLE. about 214 WOT. The WOT number should be 255 right?
Bat- 13.8
INT and L8- I haven't been paying attention. If I need it, let me know, and I'll post back.
BL- moves from 115 -140.
MPH- seems to be right according to the speedometer.
CLT- 185- 190
ATS- Varies with the outside temp.
TPS- 42 4.56
IAC- Bounces around in the low thirties.
CC 0 -250. It usually jumps up in increments of 10 to 20.
MAL 0
Rpm- 775 to 800.
Under WOT my boost gauge says 12. Shouldn't it be 16 17?
I have ordered a TT 5.7 chip.
Fuel pressure is 30 at idle and 38 with the vacuum hose off of the fuel regulator. Shouldn't it be 42 43 with the vacuum hose off, and 33 at idle with the hose on? I don't have a long enough hose to check it WOT.
It has fairly new plug wires and spark plugs.
Brake master cylinder has been replaced. Crack in the header has been fixed. I really would like to get it running like it did when new, or even a little better. I just want a quick street car that I may take to the track once when I get the motor right. If I could get her in the 12's, I would be very happy.
I'm guessing I should start with a fuel pump and a torque converter. Any suggestions? I would prefer not to have a hot wire kit. It would like to leave the turbo, intercooler, and injectors stock.
Is what I want possible?
What am I missing?
Sorry to be so loooong winded, but as I'm learning, these cars can be complicated!!
Thanks in advance, Nate
Torque Converter. Anybody know what kind it might be?
Bat- 13.8
CLT- 185- 190
TPS- 42 4.56
MAL 0
Rpm- 775 to 800.
What am I missing?
