My T/C is not loocking up and to troubleshoot the problem I want to wire a temporary circuit to bypass the ecm and brake pedal switch. Basically I want to apply the 12v and ground to the lock up solenoid to see if the problem is in the trans or in the wiring or other hardware. Which pins do I use on the trans connector to make this possible. Thanks Steve
