O.K guys was sitting in traffic and the car died, tried to restart no luck towed it home started troubleshooting. decided to change crank sensor and it's adjusted right, still no start fuel presure is at 40psi when cranking, found no spark on two plugs, so I changed the coil pack now I have spark on all plugs again, checked injector pulse and I have that. I am tired of just throwing parts at this thing with no luck. Could this be a bad cam sensor, if so do you just replace the cap or the whole thing??? also would a bad fuse link cause this I don't know waht else to do, have been doing everything in the troubleshooting tree and no luck any suggestions would help!!
