have n/a regal putting rebuilt hot air engine in it.hooked everything up i think. engine primed oiled getting fuel but no spark beleive to hooked up all grounds hot wire to ecm. getting fire to all my sensors but no spark
I would check the setting of the cam sensor. This tells the ECM the position of number one cylinder in order for the ECM to send spark. The next culprit could be the crank sensor. If this checks out look at the IGN coil module and pak. This should get you started. Keep us posted. Brad
is timing the same as intercooled if so timing is correct new crank and cam sensor.i believe my original coil and ignition module was faulty(melted plastic)had a okay 86/87 module and coil used it before i found out wiring is different than the hot air.would using a 86/87 module on un modded hot air harness screw it up?
