I need help, I have got a miss in my car now that I can not find and want to put it out there to see if anyone else has come across this before.
the car runs normal until 7650 rpms and then it starts to break up, as if it is on a rev. limit. the car has stock coil module with the dis4 box, stock cam and crank sensors, felpro 160 lbs. I have leak the motor and it is ok about 3% on all but the two center cly. and they are 8%. I have changed valve springs, plug wires, coil and module, change to the new dis4 high output box, change the harness for the dis4, changed my rpm box for the shifter that has a 7800 chip in it and I have to change to a 7600rpm chip after about two runs because then the car will not pull to 7800 in first gear. the first runs off the trailer the car will go to 7800 in first.
On the log it show good voltage while this is happing about 14.3, nothing funny on the corr.% or the A/F, boost, nothing looks funny but the rpm line. I have change or put new ends on all the power and ground wires and solder all the new ends on. Have good grounds straight from the battery, motor and frame.
The high end rev limit is set at 8500rpms and I moved it up to 9000rpms this weekend at a race to see if it changed anything but it didn't. I even by passed the msd box and put just the stock stuff on the car but it would not run with out that extra juice.
Could there be something in the felpro box bad that could do this? the settings in it are higher than when it starts to miss.
Has anyone had this msd setup and changed to a dist. set up? What all do you have to change and do to the harness to get it to work. I need this damn car fixed so I can win the points down here.
Thanks for any help anyone can give
Richie
Richie
