Need Hotair Help
leehatten
turbo rust
Guys i know that i have low spark which is causing my 85 gnnot to fire up i have chan the cam sensor crank sensor coil pac ignition module wires spark wires and plug i dont know what it could be any ideals can any one help. It still could be the ignition module do any one have a spare for a hotair car if so you can call me with a price need it asap 2243940 cell 4886214 hm
thanks guys for all your help.
LEE
Are you positive that it is indeed the ignition system?? Seems like you changed most everything associated with it. Have you checked the fuel system or even the engine computer? In any case, hope you figure it out.
:cool:
I have three engine computers and two stock chips and have checked the fuel pump so now i dont know what else to check the timming belt was change about 200 miles ago new alternator and battery.Also chaged the maf and the o2 sensor. The current ecm i got from auto zone about two hundred miles ago. I have had the compression check it was great. I plan to change the fuel to a Wb 340.
Hotair Hell
Ok i have checked the fuel pressure and i am getting like 37psi. So i thinking the the ign. module and i am wondering if one have a spare one lying around that i can buy ot use to test with let me cuz im about to go on a lil trip to thailand next hoping to get this thing running this weekend. or at least started i may need to start with setting the crank sensor and the cam sensor i need a lil help doing it i dont have a cam tool.
Lee
help
hey thanks i need all the help i can get i getting fustrated with the car. Thinking bad thoughs. if u have arent to busy just give me call 2243940 thats my cell
