Need power steering reservoir
Squid4life
Anyone out there have a nice one for a good price? I have a good, clean cap, but one of the nipples/fittings is cracked so just need the res. Need a price shipped to 91913.
Thank you!
I do not have the turbo plastic one but I got several good used GM metal ones both outlets face forward has cap on it and its metal basically same size as the plastic one comes out of a later model GM van...
also has mounting bracket with almost same distance between the two holes to attach like your original does. Cheap option compared to what you can expect to pay for a plastic one.
This is just $29.95 to your door.. Member its metal so unless you back your car over it it will not crack. Has the two same size inlet outlets that your Buick has.
denniskirban@yahoo.com
Dennis,
I will have to search online for a pic. I never knew those were another option, but for the price they might be the right option for me!
Dennis,
Here is how you can find aphoto it is photo 4 in my 05-07-2014 inner circle go to our website and locate that weekly inner circle in that photo I show 3 types the first one (left one) is the one that I have sold several of as both lines point forward and its basically the same size as the plastic one.
Trick is to make sure when you route the lines the lines have no sharp bends in it. This is a used item so if you buy it clean it out real good before using it.
if you can't locate that inner circle photo 4 advise and I can take a picture of it.tomorrow.,
Dennis, I looked at the picture in your "Inner circle" and indeed the one on the left seems best suited to replace the GN's original plastic one. My question is this: What kind of car is it from?
Thanks,
Claude. ;)
