- May 26, 2001
I'm going to be installing an Infinity Reference 7521a amp to power my rear Infinity 6x9s and would like to hear some suggestions on the best way to route the power wire up to the battery? Should I just route it through the factory grommet beside the power brake booster then back behind the motor? Or should it be routed in front of the motor underneath the radiator cover over to the battery? Or possibly run it with the other ECM wiring harness grommet on the passengers side? I would like to avoid any RMI interference that might be caused by the power cable being close to the CCCI unit if behind the motor, or any that might come from the ECM wiring. Any suggestions would be greatly appreciated as I'm tackling this project today and tomorrow.
Thanks.
Patrick
Thanks.
Patrick
