Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Anyone has a spare ECM that I can try out?
DAMN I changed everything and still can't get #6 to run!
Changed injector harness, changed plug wire 2 times, plugs AC23's @0.032, coil/Coilpack, O2 sensor, swapped injectors around, compression is good, leakdown ok, etc.
Other cylinders are all sooted. MAF is at 5-6 @ idle. FP 42 static, TPS 0.42, IAC 18. TT chip, voltage 14 @ idle
I am starting to suspect the ECM. What do you think?
