Need some help please.
scot w.
GNSperformance.com
I am in the process of removing my stock (Analog) dash cluster. I already un-hooked the speedo cable, the vss clip, and the lights. Basicly the thing is laying there with the boost/tach wires only still hooked up
The only thing that doesn't seem to have a clip to un plug is the wires that go to the factory tack/boost gauge. How does everyone disconnect these wires? Is there a clip i'm missing?
It Must come out tonight so if you know for sure or have pic's please post so I can get this out.
Thanks in advance!
Scot W.
tricky part....the plug(6-8 inches on the harness from the cluster) is sometimes found between the stereo housing and the cluster a SOB.....
Gary thanks for the quick responce buddy! I will go down there now and see if I can find it.
Scot W.
Found the plug stuffed behind the core support! Thanks Gary! ;)
Scot W.
