SuperSport30
- Nov 5, 2006
got some powerlogger values that i need som help with.
i tried to set my iac with my powerlogger and i couldnt get it
to set at 20-25 counts.
tried to set the idle at around 750. iac wouldnt register.ran the screw all
the way in to around 2200 rpm could only get it to register around 12 or 13 counts.
tried both ways "the unplug w/ computer in diag mode" and the set to
20-25 counts. if the veh is idling at 700-750,the iac registers 0
secondly, o2 is fluctuating wildly it follows injector cycle at idle
duty cycle oscillates between 3.2% and 3.9% is this normal or do i have one or mre bad injectors?
blm is bouncing at idle between 131 and 160. i would love to get this thing running right!
thanks
SS
thanks
SS
