need some ideas
87hottness
ok guys just picked up a casper knock gauge but i need some ideas on where to put it i already have the pillar 3 gauge pod and it full lol do they make some thing that will match the dash that i can use any ideas would be great thanks
they are everywhere....goes in the console under the radio...i would personallymove something out of ther pillar and put the knock gauge there so you can see it like a heads up display
That one won't work I have the split bench no center console and I'm am planning on putting it in the pillar just need a place to move A gauge
Back on my first GN I didnt want to damage the interior with gauges so I bought an extra nameplate that goes above the glove box then cut it out to hold a gauge. Will have a hole behind the plate but if you take the gauge out just install a new nameplate and its covered.
I would make sure that is your most prominent gauge. Knowing knock is pretty damn important. I have mine as the top-most on my 3 gauge A-pillar, along with boost and oil pressure. I figure the most important things need to be the easiest to see. Hope it helps!
