Need the factory brass turbo oil feed block piece
d0n_3d
Boost is good.
Does anyone have an extra brass block laying around? This is the block that has the two oil ports one going to the turbo feed and one to the oil pressure sensor that screws in the block??? Thanks!
What size stall torque converter are going to run with that turbo? Motor sounds great!
Brass Fitting
I have one Don. Make offer? Anything else you need? I have alot of extra parts I need to get rid of!
I have a 10" non lockup 3500 stall converter I'm running...it should help spool this 76 BB turbo no problem. Plus the bigger CI on the motor will help too.
