Need your help with engine load conditions
TURBOZ
A while back I posted about a pop through the exhaust. Crieg you where right, I was loading up the cylinders with fuel, too rich. I solved that problem on the VE table. However, I had to pull about 15-20 points off the VE table to solve that problem. My question, now when I put a load on the motor, daily driving, the car needs more fuel where i had to remove the 15-20 points. How should I fix this delema?
The original issue was the car would pop when I let off the gas or when I would rev the car in neutral.
Any input would be great!
When the car is loaded, you should be in a different part of the map then where you were having trouble popping on decel. Decel is in the lower part of the screen, and the higher up the cursor moves, the greater the engine load. give it what it wants - I bet that adding fuel under load won't give you any trouble with popping on decel.
