Thanks for all of the ideas.
The idea behind connecting the oil galleys after the feed to the rear main is to ensure that all of the mains and rods are a higher priority than lifters and valve train.
The way the stock oil system is designed, the d/s oil galley, which only serves the d/s valve train, is a higher priority than the mains 2 through 4 and the rods they serve.
With the needle bearings, the mains can be promoted ahead of even the cam now.
Since the p/s valve trains and the mains/rods are fed from the same galley, I don't see a way, however, of serving the mains/rods ahead of the p/s valve train.
I am a little nervous about the extra plumbing 'cuz it sure would be a PITA to troubleshoot and repair.
As for the cam, smaller journals, lower lobes. smaller base circle and longer pushrods appear to be in order.
Later,
Buzz
