RED LS1
SENIOR MEMBER
- Dec 31, 2001
Long story short.... I bought a good running 50,000 mile GN. I took everything off and cleaned and painted and replaced the usual items. Intake gasket, V/C gaskets, plugs, wires, O2 sensor, power plate, new 60lbs injectors, TT chip etc....
I replaced the stock FPR with a Accufab. It pours gas out of the O-ring at the rail. I tried both supplied O-rings and also 2 stock Injector o-rings and it didn't change a thing. I put the stock one back on and it is perfectly fine.
I drove the car around a little with the stock one on and it's now bucking under light boost. I'm not sure if it's because the Stock FPR is on or some other problem but what's some trick you guys are using to seal up these reg's. Some say the Hex nut is hitting the rail. Some say parts store O-rings seal it up. My friend just bought a new one last week and his is fine.
Need some ideas here
