new converter problems? help!!!!
sdteb
trying to get it like you
i had a new 3000 stall put in and got the car back today..every thing feels fine then i decide after a good bit to try it out...well it feels like the motor when i get in it is in neutral or revs up real bad or the feeling of a bad transmission....it wont really hook up and just revs up....any ideas...the tranny is in good shape...the only other thing i did was put a shift kit in and new tcc solenoid....also used amsoil synthetic tranny fluid...any ideas...hell once i got home tonight i cant hardly give it any gas to get it going....
have you rechecked the trans fluid level (with engine running).. sometimes, after a drive, the fluid will be low after being fully run down the road.
just checking
how many quarts....3.5? correct?
what!??!?!?! I don't know the exact number, but after a converter change and pan drop.. you're looking at 7-10 quarts of fluid.
fluid
just checked again..it is good on the fluid level
i used almost 2.5 gallons of fluid...
sorry my brain is a little fried...
"hell once i got home tonight i cant hardly give it any gas to get it going...."
what did you mean by this? I'm assuming the basics - detent hooked up and set correctly, torque converter stabbed correctly, valves replaced with shift kit went in as the old ones came out?
phone number to call you?
or call me 6155337172? just went for a drive...have to tell you have it does...first gear is good once it hits second give it any gas feels like neutral...
ok more info
i have first gear just fine...after that it feels like i have a big ass stall in it...just revs but no movement unless i baby it but even then feels fu#$ed up this is in my TTA
