NEW Electric vacuum pump kit
WHITE T
Baer Brake Systems
Guys,
I bought this awhile ago and never used it.
The harness is a Racetronix for a 3 wire vacuum pump. From memory the pump is a later model 3 wire off a Camaro.
The pump was purchased brand new (internal foam was removed), I built a bracket (seen in the pic) to mount this in the area of the factory charcoal container (under the inner fender).
$150+ ship for all the parts.
Yes, there are a number of post on here about guys that have adapted the electric vacuum pump to help cut down crank case pressure and minimize oil leaks.
Racetronics makes the harness and this is a GM pump.
