New engine set up help
1fast87gn
Just started our new combo this moring and would like to see what the experts would like to see on the scanmaster.
tps is set at .44 volts idle is at 800 rpm
what would you like to see in o2 volts at idle and the other readings at idle and at what other rpm.
combo
ported irons
75 injectors
45a turbo
extender extreme chip
translator plus
ls-1 maf
we will be hooking up direct scan today and will have more info later.please help us not urt the new engine.
thanks
Steve
O2's ad idle should bounce around all over the place and at WOT you should be between 780 and 820mV
you said your TPS is .44 @ idle... what is your IAC at?
hope that helps
