Hi, just got a new 87 gn. The problem I am having is when i mash the gas, when the boost gauge gets up to 15 psi the (i think) fuel cutoff is comeing on, I assume its overboosting, trying to figure out why. The wastegate vacuum hose goes into the t, and then goes into the solenoid.....The wastegate can be turned by hand if you pull on it, so it is free.....
That does sound like what the problem is right? It just cuts out completely for a second over and over like a rev limiter.
So we just need to figure out whats the cause of the overboost.
Also, for some reason the tcc was staying locked. It DID unlock in 1st which tells me the solonoid itself is not stuck on. Brake pedal did not unlock it either, so im guessing it was grounding out or the ecm was commanding power to it..... Any common problems there? Did it once....
