- May 9, 2002
Welcome
FIRST thing is a scanmaster and to learn how it works. It will give you a digital reading of the coolant tempeature along with the other sensor values via the ECM. It is real easy to blow your headgaskets or even worse if you do the wrong thing with the boost!
Look at your chip. Write the numbers down you see on it and use the search feature of this site....Is it a stock chip? If yes, you need a modern chip.
You don't want to increase boost until you know how to do it without blowing a head gasket. So, wait on that, OK?
Unless your exhaust has holes in it, wait on that too.
The links in the posts above this post are good ones, check them out.
Gauges are good. Personally, I've used an audible knock detector instead of a knock gauge....Personal preference.
Gather some information first and then do your first modifications. Your car will do a lot better that way
I'm a new member here, this is my first post and i just picked up a 86 GN with 59K original miles I have always had mustangs in the past and i have a few questions about my new car this a totaly new animal to me.
I don't like the fact that the Gn doesn't have any guages in it and want to add a water temp and oil press guage, where is there a place to add a mechanical water temp in the intake?
second thing i'm wondering is are the tps sensors adjustable on these turbo 3.8 engines? or should i just replace it, the car a spot where it stumbles and only does it at one spot when your accelorating
thanks!
